Wireless Security
Dear All,
I have a setup of RB433AH router with 40 wireless users. All are connected to WLAN’s with security profile. Now i wanted to connected all these device with the help of access list. Is there any method by which some user can connect with security profile and some with access-list so that one bu one i can shift all the users to access-list.
Thanks,
DirectLogic
Use an virtual acesspoint with another ssid
A network secured with mac-address filter can still bugged and mac addresses can be copied
Greatings
Thanks.
Its works in testing environment and i will check in live also.
Direct Logic
