Hi All
Please refer to this diagram
I am looking to set up the senario thus …
Router A and B are cisco routers.
Network A is our hosted environment
Switch A and Switch B are 10/100 switches.
Mikrotik A & C are running on 531 routerboards
Mikrotik B & D are running wrapboards
I want to do the following
- Load balance over Link Mikrotik ABCD
- Failover Mikrotik ABCD
- Router A and Router B have a serial link as well (Labeled on diagram) I want to failover the wireless links in the event of packet loss or power down. (Mikrotik A C has backup power for 3 days [ups] mikrotik b and d will have in 2 weeks)
- I need to address all the mikrotiks using a C Class public addressing scheme.
These are my ideas:
- Is it possible to Bridge both wireless connections into one “huge” wireless link?
- Will the failover between the wireless networks be seemless.
- Can you loadbalance 50:50 netween the links? Could it be 70:30 ?
- Could you control wireless load balance and failover on mikrotik? could it send notification on failover or link down ?
- I want to run a routing protocol on the Cisco Router A and B Perhaps EIGRP - maybe we could redistribute the wireless links into Eigrp.
Let me know what you think
Regards
Malcolm Siegel
