If I connect my PC directly to SXT LTE6 kit via ethernet cable, everything (including intenet) works as expected with default factory configuration.
But if I connect SXT LTE6 kit to eth-1 slot of hAP ac² router via ethernet cable, internet is not available inside WiFi network.
What should I setup to solve this?
Thanks in advance.
I would guess default IP on both boxes is something out of the Mikrotik default I range 192.168.88.1/24
So conflict as the router don;t know where to sent that data to…
You will need to configure the IP range on either LTX or hap ac2 to be different bewttn each user (for example 191.168.8**9**.1/24)
If you don’t know how, use Quickset on the LTX.
