Wireless Siganl stops working
We have an environment using about 50 of the RB711-2hnd with outdoor 16 dbi arc wireless antennas. We have the radios turned down to 300 MW and spread out on channel 1,4,8,11 to minimize cross talk. The aps will seem to run fine for some time. Then all of a sudden people are connected to the aps getting valid IP address but can not get on the internet or ping the DGW. The signals on the radios have then gone down tremendously after sometime they then begin to work again. We have thousands of mikrotiks in the field at 100s of sites and no issues. Is mikrotik just not gong to work for me at this location is there something in the wireless I can change. Currently all we change is the channel ssid, and power output everything else is default. Also sometime the radio reports the client device is over 10 km. Any help or thoughts…
Thank you,
Elec
If there are no disconnections, and they get IP addresses, it is not wireless related. Can you make a supout.rif file at the moment of the problem? Also it would be great if you upgraded the devices first, to make sure this is not a fixed issue.
