Wireless signal issues
I have 4 high gain antenna on a pole. They are on channels 2,4,7 and 11. The snr from clients looks great 40+ snr the ccq looks great 80 or more. However the throughput sucks. I get TX at 54mbps and RX at 1mbps every so often it will jump up to 5 or 6 mbps and the user can browse for a few minutes till it jumps back down to 1mbps. This happens to about 8 out of 10 clients and on all the radios. Other radios in different locations at this property work fine. I also have other locations with 4 antennas all on the same pole. Is there something I could be missing?
first, posting more info about Your config etc.
What more info are you looking for?
here is a detail print of my wireless settings
R name=“wlan1” mtu=1500 mac-address=D4:CA:6D:56:EC:76 arp=enabled
disable-running-check=no interface-type=Atheros 11N
radio-name=“D4CA6D56EC76” mode=ap-bridge ssid=“HOTAIR” area=“”
frequency-mode=manual-txpower country=united states antenna-gain=0
frequency=2442 band=2ghz-b/g/n channel-width=20mhz scan-list=default
wireless-protocol=802.11 rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
distance=dynamic tx-power=23 tx-power-mode=card-rates
noise-floor-threshold=default nv2-noise-floor-offset=default
periodic-calibration=default periodic-calibration-interval=60
dfs-mode=none wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled bridge-mode=enabled
default-authentication=yes default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=disabled hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0
ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-
9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-
18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7
ht-txchains=0 ht-rxchains=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192
tdma-period-size=2 nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30
nv2-security=disabled nv2-preshared-key=“” hw-retries=7 frame-lifetime=0
adaptive-noise-immunity=none hw-fragmentation-threshold=disabled
hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0
rate-selection=advanced multicast-helper=default
Here is a list of currently connected users
interface=wlan1 mac-address=00:22:5F:6D:FE:82 ap=no wds=no bridge=no rx-rate=“1.0Mbps”
tx-rate=“48.0Mbps” packets=3210,3864 bytes=248562,305942 frames=3210,3864 frame-bytes=229368,282758
hw-frames=4302,4103 hw-frame-bytes=406178,381230 tx-frames-timed-out=0 uptime=43m last-activity=0ms
signal-strength=-62dBm@1Mbps signal-to-noise=50dB signal-strength-ch0=-62dBm
strength-at-rates=-62dBm@1Mbps 0ms,-63dBm@2Mbps 46s440ms,-64dBm@5.5Mbps 4m39s270ms,-66dBm@11Mbps
20m21s240ms,-61dBm@18Mbps 40m15s890ms,-63dBm@24Mbps 41m21s850ms,-61dBm@36Mbps
41m39s930ms,-62dBm@48Mbps 42m58s180ms,-62dBm@54Mbps 42m58s450ms
tx-ccq=95% p-throughput=27135 distance=41 last-ip=192.168.11.155 802.1x-port-enabled=yes
management-protection=no wmm-enabled=yes
2 interface=wlan1 mac-address=00:24:2C:96:F9:7F ap=no wds=no bridge=no rx-rate=“1.0Mbps”
tx-rate=“11.0Mbps” packets=930,546 bytes=961914,37994 frames=930,546 frame-bytes=956982,34718
hw-frames=1866,1849 hw-frame-bytes=1746956,79094 tx-frames-timed-out=0 uptime=42m44s
last-activity=9s990ms signal-strength=-71dBm@1Mbps signal-to-noise=41dB signal-strength-ch0=-71dBm
strength-at-rates=-71dBm@1Mbps 9s990ms,-74dBm@2Mbps 42m20s170ms,-75dBm@5.5Mbps 42m20s270ms,-
75dBm@HT20-0 42m20s350ms,-72dBm@HT20-1 42m26s470ms,-73dBm@HT20-2 42m26s850ms,-
73dBm@HT20-3 42m29s450ms,-72dBm@HT20-4 42m39s670ms,-70dBm@HT20-5 42m39s870ms,-
71dBm@HT20-6 42m40s700ms,-72dBm@HT20-7 42m41s900ms
tx-ccq=47% p-throughput=5108 distance=5 last-ip=192.168.11.213 802.1x-port-enabled=yes
3 interface=wlan1 mac-address=00:13:CE:A7:28:CB ap=no wds=no bridge=no rx-rate=“54.0Mbps”
tx-rate=“6.0Mbps” packets=1529,1075 bytes=1955831,181720 frames=1529,1075
frame-bytes=1946675,175270 hw-frames=3968,1084 hw-frame-bytes=5336373,201286 tx-frames-timed-out=0
uptime=3m2s last-activity=7s110ms signal-strength=-66dBm@1Mbps signal-to-noise=46dB
signal-strength-ch0=-66dBm
strength-at-rates=-66dBm@1Mbps 1m37s880ms,-62dBm@2Mbps 2m21s880ms,-62dBm@5.5Mbps 2m21s470ms,-
62dBm@11Mbps 2m21s360ms,-69dBm@12Mbps 2m17s650ms,-68dBm@18Mbps 2m17s540ms,-
65dBm@24Mbps 17s950ms,-67dBm@36Mbps 14s200ms,-63dBm@48Mbps 12s220ms,-64dBm@54Mbps
7s110ms
tx-ccq=8% p-throughput=181 distance=1 last-ip=192.168.11.131 802.1x-port-enabled=yes
4 interface=wlan1 mac-address=64:20:0C:7A:C3:BB ap=no wds=no bridge=no rx-rate=“5.5Mbps”
tx-rate=“1.0Mbps” packets=12,26 bytes=2455,2138 frames=12,26 frame-bytes=2383,1982 hw-frames=39,195
hw-frame-bytes=8042,6662 tx-frames-timed-out=0 uptime=30s last-activity=690ms
signal-strength=-81dBm@5.5Mbps signal-to-noise=31dB signal-strength-ch0=-81dBm
strength-at-rates=-74dBm@1Mbps 1s250ms,-80dBm@2Mbps 10s480ms,-81dBm@5.5Mbps 690ms,-85dBm@6Mbps
20s130ms,-80dBm@HT20-0 3s430ms,-82dBm@HT20-1 6s850ms,-80dBm@HT20-2 7s430ms
tx-ccq=16% p-throughput=886 distance=2 last-ip=192.168.11.177 802.1x-port-enabled=yes
i would suggest you disable a radio, and move the remaining three on the only 3 non-overlapping channels, which are 1, 6 and 11 in order to avoid self-interference.
try this and post the results here.
