Wireless Sniffer...
Hi, this is a silly question.. can MT capture the wireless packets, save the file and the use aircrack to crack a WEP key?
The above post is 3 years old but I have a similar question. Is it possible to install aircrack ( http://www.aircrack-ng.org/ ) on router os and in effect turn the os into a wifi sniffer/wep breaking os? Has anyone tried installing aircrack?
No, you can`t do that…
