wireless specification
hi everyone
wireless specification table in brouchure of routerboards mening what ?whats does discribe exactly ?
what part in this PDF do you mean?
This part :
Datarate. Tx. Rx sensitivity
6Mb/s. 25. -96
54Mb/s. 20. -81
This is Basic knowledge if you are working with wireless systems
This means that the Wireless Card will send
25 dbm @ 6 MBit
And only
20 dBm @ 54 MBit
This is normal for WiFi Equipment
The Part with the -96 dB says that the connection with 6 MBit is possible until you are under -96db
With -97 dB you are losing connection
With -81 dB or better you get 54 MBit under -81 dB it starts to go to 48MBit
