wireless speeds slow... in Access Point mode.
hello,
after upgrading to the latest ROS 6.11 users have started experiencing very slow WiFi speeds in Access Point Modes…
the last ROS was 6.6 and everything was working perfect… since the update the speeds have dropped drastically.
does anyone here facing similar issues??
On what board you did the upgrade?
Try to reset the wireless interface configuration and check again if it gets better or not.
i am using the RB-711UA-2HnD
i also tried to reset everything but still the problem continues.
with hardly around 15-16 clients the file copy speeds do not exceed 400-500 kbps
Please, try to install the wireless-fp package and check how it is working.
How far are the wireless clients?
What equipment the clients are using?
What wireless protocols are you using?
where can i get the wireless-fp package?
