Wireless Station to AP Bridge
I’m trying to figure out an issue with the mAP lite using it as a station on the AP with a virtual network being an AP Bridge. I got it working with the station being the primary and the virtual being the AP Bridge using 6.36.2 but the issue I’m running into is if the station can’t find the SSID that has been hard coded in the config it won’t bring up the AP Bridge making it difficult to use as a portable router. I can work around with with a laptop connected via ethernet to fix the SSID but is their a way to have the AP Bridge come up even if the station isn’t connected to something to make this easier. I have tried it reverse where the primary is set to AP Bridge and the virtual to station but that doesn’t seem to work. This is a great feature just would like to make this a little bit easier to use.
