wireless tp-link router and mikrotik
hy
i have an RB1100AHx2 router with port 2 and 6 as master ports (my router network 192.168.10.0, gatteway 192.168.10.1)
i have a pppoe connection to internet from my isp on port 4
all works great
what i want is to put a wireless tp link router on port 2
what i did on tplink
disabled dhcp
set network in the same class as mikrotik router (router ip: 192.168.10.99)
set gateway and dns as my mikrotik router gateway (192.168.10.1)
i have an ip/camera behind router tplink (192.168.10.253) that i can connect from web
but i cant connect to internet from tplink router, but ping to 192.168.10.1 works
my nat on mikrotik is
Action Chain Src. Address Dst. Address Protocol Src. Port Dst. Port Any. Port In. Interface Out. Interface
1 masquerade srcnat pppoeconnection
what rule should i put to work
thanks
On the TP-Link Wireless Router, I would set a automatic WAN IP so it will get is range from the 192.168.10.0/24 address from your RB1100AH then once the TP-Link has a WAN IP, Forward the ports from the RB1100AH to your TP-Link WAN IP, Then from the TP-Link router iself forward the port to your IP Cam :slight_smile:
