At the beginning, this link was very solid (TX/RX CCQ 95%-100%), but suddenly the link drop very bad.
Is the problem at AP site or Client site ?
At AP site: Overall TX CCQ: 100 % ; Signal Strength -87dbm ; Noise Floor -106 dbm.
At Client site: Overall TX CCQ: 22 % ; Signal Strength -72dbm ; Noise Floor -90 dbm.
I already replaced device (RB+Card) at Client site, but problem still same.
Already changed frequency, still same.
Is it antenna / pigtail problem in client site ?
or
Problem in AP site ?
I run an hourly SNMP scan on all APs to gather the SNRs for all connected clients, and stuff the results into a database so i can see a graph of the SNR for any 1 client, or for the Average of the AP.
This helps a lot in these kind of cases, because you can see when it started to drop off.
The Classic case is where a Tree grows in front of some CPE - you can see the SNR gradually reducing.
I keep meaning to write the software to email me when a CPE or AP Average SNR starts dropping … but haven’t yet.
It is disheartening that this thread turned into something other than the problem at hand.
I already changed antenna, no luck
Already changed polarity V to H, no luck
Is it possible if the RX Sensitivity in AP side was damaged ? So AP could not hear Client clearly. Please advice.
I already changed antenna, no luck >
Already changed polarity V to H, no luck >
Based upon your noise floor at the AP side I would be inclined to beleive that in fact you are correct that the receive amp may be deafened.
