Full config is below, but basically I have:
wg0 - Works can ping over the interface
bridge-1 is a bridge between my uplink eth1 and my desktop eth2 - Works has internet
bridge-2 is a bridge for wireless - Wifi works and I can ping over the VPN on the bridge-2 interface on my tik
DHCP is configured and gives assignments over wifi.
The problem is nothing that connects to my wifi gets internet over the VPN or at all. Not sure what I’ve done wrong, any help would be very good thanks.
add name=bridge1
add name=bridge2
/interface wireless
set [ find default-name=wlan1 ] country=xxx disabled=no mode=ap-bridge ssid=lolvpn
set [ find default-name=wlan2 ] ssid=MikroTik
/interface wireguard
add listen-port=7887 mtu=1420 name=wg0
add name=VPN
add name=pool1 ranges=10.10.11.0/24
add address-pool=pool1 interface=bridge2 lease-time=1h name=server1
/ip vrf
add interfaces=VPN name=vrf-vpn
add bridge=bridge2 interface=wlan1
add interface=bridge2 list=VPN
add interface=wg0 list=VPN
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=xxx endpoint-port=51820 interface=wg0 public-key=“xxxx”
add address=xxxxxx interface=wg0 network=xxxxxxxx
add address=10.10.11.1/24 interface=bridge2 network=10.10.11.0
/ip dhcp-client
add interface=bridge1
add address=10.10.11.0/24 gateway=10.10.11.1
/ip firewall mangle
add action=change-mss chain=postrouting new-mss=1380 out-interface=wg0 passthrough=no protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat out-interface=wg0
add dst-address=0.0.0.0/0 gateway=wg0 routing-table=vrf-vpn
