Wireless VLAN Bridge No Internet Access
I have a issue and it probably something simple but need someone else to take a look.
What I am trying to do is setup the RB751U-2HnD to have 2 SSID's with one on VLAN 10 and the other on VLAN 20.
The local network when wired in works just fine.
Take a look and let me know what I am missing?
may/08/2013 15:07:42 by RouterOS 6.0rc14
add l2mtu=1594 name=bridge-VLAN10
add l2mtu=1594 name=bridge-VLAN20
add l2mtu=1598 name=bridge-local
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
/interface vlan
add interface=ether2-master-local l2mtu=1594 name=vlan10-PrivateWireless
vlan-id=10
add interface=ether2-master-local l2mtu=1594 name=vlan20-GuestWireless
vlan-id=20
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys wpa-pre-shared-key=36D402201FF1 wpa2-pre-shared-key=\
add authentication-types=wpa-psk eap-methods=passthrough group-ciphers=tkip
management-protection=allowed mode=dynamic-keys name=CVACWLAN
supplicant-identity="" unicast-ciphers=tkip wpa-pre-shared-key=
management-protection=allowed mode=dynamic-keys name=CVACGuestWLAN
/interface wireless
set 2 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=
indoors hide-ssid=yes ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=
ap-bridge security-profile=WLAN1 ssid=WLAN1
add disabled=no l2mtu=2290 mac-address=D6:CA:6D:53:6F:92 master-interface=
wlan1 name=GuestWireless security-profile=GWLAN ssid=Guest
wds-cost-range=0 wds-default-cost=0
add disabled=no l2mtu=2290 mac-address=D6:CA:6D:53:6F:91 master-interface=
wlan1 name=PrivateWireless security-profile=PWLAN ssid=Private
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=default-dhcp ranges=10.110.1.100-10.110.1.200
add name=GuestWL ranges=172.16.101.100-172.16.101.200
add name=PrivateWL ranges=10.110.11.100-10.110.11.200
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add address-pool=GuestWL disabled=no name=GuestWL
add address-pool=PrivateWL disabled=no name=PrivateWL
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-VLAN20 interface=GuestWireless
add bridge=bridge-VLAN20 interface=vlan20-GuestWireless
add bridge=bridge-VLAN10 interface=PrivateWireless
add bridge=bridge-VLAN10 interface=vlan10-PrivateWireless
add address=10.110.1.254/24 comment="default configuration" interface=
bridge-local network=10.110.1.0
add address=.../28 comment="Outside IP" interface=ether1-gateway
network=...
add address=10.110.11.254/24 comment="Private Wireless" interface=
bridge-VLAN10 network=10.110.11.0
add address=172.16.101.254/24 comment="Guest Wireless" interface=
bridge-VLAN20 network=172.16.101.0
add address=10.110.1.0/24 comment="default configuration" dns-server=
208.67.222.222 gateway=10.110.1.254
add address=10.110.11.0/24 comment="Private Wireless" dns-server=
add address=172.16.101.0/24 comment="Guest Wireless" dns-server=
208.67.222.222 gateway=172.16.101.254
add action=drop chain=input in-interface=ether1-gateway protocol=icmp
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=
ether1-gateway
add chain=forward comment="default configuration" connection-state=
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration"
connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway
add distance=1 gateway=... (Outside Route)
You have your vlans on ether2 but have ether2 in a bridge. Try setting your vlans interface to the bridge ether2 is in (bridge-local).
Well yes that will work but it gives out the 10.110.1.* address
I would like to keep the network separate especially the guest network.
So doing that defeats the purpose of my goal unless I am missing something.
add bridge=bridge-local interface=GuestWireless
add bridge=bridge-local interface=vlan20-GuestWireless
add bridge=bridge-local interface=PrivateWireless
add bridge=bridge-local interface=vlan10-PrivateWireless
You had your bridges correct the first time. Don’t put everything in the same bridge. Change your vlans interface in /interface vlan interface to bridge-local
Okay I changed it check the following.
I won’t be able to test till morning.
/interface vlan
add interface=bridge-local l2mtu=1594 name=vlan10-PrivateWireless vlan-id=10
add interface=bridge-local l2mtu=1594 name=vlan20-GuestWireless vlan-id=20
That’s what I was talking about.
Let me know if it works.
Thanks “cbrown”
That was the fix appreciate the assistance on this.
No problem. I’m glad you got it working.
Hi cbrown,
It worked for me also. Please can you advise me on this question?:
I have cisco switches from both sides (ethernet & wireless), which use native vlan id=1 (untagged) for management.
Is there any way to allow untagged native vlan id=1 pass through bridge-local?
If i create another vlan with id=1 then it is tagged and there is no communication.
Trying 3 days without solution. Any help would be greatly appreciated.
Andreas K.
PS: I could change the management vlan on switches but if there is a workaround with ROS it would be the best solution
