Wireless Vlans
I am trying to set up a rb433ah as an access point with vlans on the wireless interface. I want the routerboard to be a layer 2 bridge (no routing). I have a cisco router to handle the routing. I currently have a bridge interface set up with all the ethernet and wireless interfaces added to it, and it works as expected. What I want is if someone connects to the wlan1, that traffic will be tagged with vlan2, and if they connect to wlan2, traffic will be tagged with vlan3. Or if it could be done like our Cisco AP’s where each vlan you set up has its own ssid, that would work too.
Thanks,
Mark
add your vlan interfaces to ethernet interface. bridge wlan1 with vlan1, wlan2 with vlan2, etc.
Thanks, this does exactly what I want.
