Wireless WDS issues
I have run wireless with ap wds mode and on all the wds connected clients i’m getting same packet and Tx rate on status on all my AP which are on same vlan. i have attached the torch result, what might be cause behind this. it is showing 0.0.0.0 as dst address.
Probably because arp is enabled. It has to search the network to convert mac addresses and ip addresses.
