Wireless Wire Cube - Lost Access
After changing interface setting on the master unit(v6.48), we created a management vlan, we lost communication with the device and have unable to reset it following the procedures on your manual.
The first difficulties is to determine which led you are referring as to the one that flashes green and then goes to solid green, because beside the signal strength indicator leds, there are 3 leds:
-Blue with an icon symbol of power, an this is blue, and as far as we can tell it doen’t flashes.
-A light blue (maybe its tainted by the blue power led) led with a symbol representing a user this one flashes and appear to go solid after
-A light green with a symbol representing a computer/connectivity that flashes when the network cable is connected to some device.
First question is what led should we be looking when pressing the reset button?
Second Is your manual correct by stating that the reset button should be pushed with the device powered of?
How long should we push the reset button to obtain a factory reset?
Any help will be greatly appreciated.
