I have a set of one of the first Wireless wire cube pros after they were released. I have not tested them until now they been lying standby for a while. I set them up with the builtin scrips and they connect automatically on 60G but seems the 5G is not active. Status is Slave and not Running with message “searching” and “detecting radar”. Firmware is the latest 7.10.1 and several attempts have been made to restore config and start over. When i disable W60G Station i loose connection. Anyone can help? I think the script that setup the cubes are not correct. See attached screenshots.
Ok, had to play around with the channels on the bridge device. Also set the master to station bridge. Seems you can not leave the channels to auto on both devices, only on the master station. Some higher number channels will not work. Using superchannels. Set it to 5600 works fine now and connected.
