Wireless Wire Cube Pro Set - Default configuration after Netinstall / Reset?
If the unit is reset by Netinstall + Reset, is the configuration already present at the time of delivery automatically reactivated or does it have to be created manually?
Hitting reset config will load the config file it shipped with. So it should reconnect to is old partner.
Did this Friday when a unit decided to get stuck in net install.
