Wireless Wire Dish and vlans
I have just bought my Wireless Wire Dish and have some dificulties while configure vlans.
I would like to get both units (master and slave) connected as untagged (for managing purposes) to the switches in two locations and be able to transfer all tagged vlans from my network.
Can anybody advice me how to do that?
I think VLAN will work out-of-the-box (aka. default config)
Add DHCP-Client on bridge-interface for management
Secure your Router, and you are good to Go!
The wireless wire is transparent (like plugging in an ethernet cable from a port on your router, to a switch)
.In other words, its the settings on the two devices that determines how and what is communicated between them.
Think of the wireless wire connection as simply an ethernet cable (no config or properties).
