I was setting up the MikroTik Wireless Wire Dish and testing the config. I went to lunch and one of my curious coworkers hopped on the web interface. He accidently deleted the ethernet interface and in his panic he decided to factory reset. Thinking that would fix the problem. Unfortunately I hadnt backed up the config yet as I’d only had the Dish for about 2 hours. Does anyone have a paired master and salve config I can use to get these paired again. Maybe you could send the config with the passowrds removed or with the passwords replaced with simple temporary passwords. Thanks for your help. For the life of me I cant get them working.
