I plan to use a Wireless Wire Dish (60GHz) for 2 buildings interconnect.
I have an existing 2 port pairs LAG on HP 1950 switches, using FSO and I would like to add a third pair with the Wireless Wire Dish.
My question is if the Wireless Wire Dish supports relaying the LACP traffic required for the LAG to work.
I have already tested with Ubiquiti Airfiber 60, which doesn’t relay LACP traffic and the configuation described above can not be used.
Ubiquiti L2 support reply was that LACP is not supported on wireless networks. However the product is sold as a transparent bridge which is obviously not true (the FSOs are and they are working correctly).
Wait… why are you guys trying to relay LACP [Link aggregation] across wireless bridge? Perhaps you instead mean you wish the wireless bridge to carry your VLAN TRUNK [TRUNK] info across??..
LACP would be between two(2) network switches to aggregate bandwidth between them and link redundancy. Although the bandwidth is not really split when using LACP.
This is exactly what the requirement is. To aggregate the bandwidth and provide redundancy between two switches in two different locations(buildings) which use the wireless bridge instead of cables!
Correct me if I am wrong, but this suggestion doesn’t provide link redundancy nor aggregation. Unless you have somethind else in mind and you care to elaborate more.
Did you find out if MT can relay LACP over wireless?
Unfortunately, I wasn’t lucky enough to find someone who uses them in that way. All responses that I got, were just assumptions that it ‘must work’.
I could see you using the wireless bridge to create connection between your two building locations. But to extend LACP across the wireless bridge… just seems like more headache than worth. Especially with being over wireless.
I would have to see network topology to better understand.
But by the sounds you want to have two(2) wireless bridge links to essentially virtual wire to second building and their two switches and form LACP. Yeah no.
