Wireless Wire - not working after power outage
I’ve been using RBwAPG-60adkit - https://mikrotik.com/product/wireless_wire successfully for many months now, and no problems, even when I’ve had power cuts. Two days ago I had some electrical work done at home and needed the power off for about 4 hours. When the power went back on, all of my network, wifi etc. came back on fine, but the two WW units don’t appear to be communicating.
They both have green and blue lights on to indicate ethernet and power. I have power cycled them both many times (both are powered by PoE), as well as my router, and this hasn’t helped. I have double checked the line of sight, and connection of the ethernet cables. I’m able to see each unit when directly connected using winbox, but I don’t know what to look for or change in order to re-pair the units.
In fact, on the unit marked slave, I’m able to log in using winbox with the user and password on the label. But on the other unit, it says I have the wrong password. The label on each unit shows the same username and password as each other, so this all seems quite strange. Can anyone please help, thanks.
Finally fixed this, the master unit needed a factory reset. Bit of a mystery why this was needed after a power outage, but there we go.
Also I had to wait for a second pair of hands in order to do the reset, which was a bit annoying.
How did you go about the factory reset steps?
