I will install mine at ca 30 meters distance. Is there any configuration to make this work better on shorter distances, have read about lowering tx power etc. Is that recommended?
Also, is there a similar minimum distance for the wireless wire cube?
There is no known minimal distance for RBcube, if you are planning on having both of them on the same table (0~2m), don’t point them directly at each other
