I purchased a paired Mikrotik wireless wire. I upgraded the firmware to the latest version on the bridge and now I'm unable to connect to the station. The two units are connected and I can discover the bridge. bridge running 7.23.2 and the station is running 7.16.2. Help!
It Is not clear (to me) which situation you are in.
Wireless wire may mean different devices, RBwAPG-60adkit or Cube Pro's.
The settings in 7 should be AP on one side and station or station-bridge on the other.
The device you call "bridge" Is the nearest to you (the One you are connected to via ethernet)?
And you cannot connect to the other One? (i.e. the One connected via PtP wifi?)
Yep, so if you have MAC connection (via telnet) you should be able to connect with Winbox via MAC too.
At which point you should be able to extract the configuration of both devices and post them on the forum.
About Winbox (MAC connection point 3.b): Why you should use Winbox
