Hi there,
I’m hoping to rehouse my new wirecube pro devices with a new enclosure (I want it smaller to remove the heavy mount) I took the four screws off the back but the housing but it is still stuck on. Do I need to use my heatgun to loosen some glue? Wanted to check in case there is an easier/safer solution.
