wireless wired 60ghz
Hello, I am working a link in 60ghz 1km away, it is a test link in the beginning I managed to connect to -80 but looking for a better signal level I was moving it and the link was disconnected so that I cannot establish connection and observed that the wireless led turns off when the connection to the cpe is lost is this normal? I work with Mikrotik 5 GHz and at 60 GHz it is totally different.
regards
If you are using the wireless wire kit, 1km would be a little too far for these devices as they are supposed to cover the range of 200m>
Wireless wire dish and LHG 60G works better in this situation.
