WirelessAP to hAP AX2 Wireless connection
I’ve got a MikroTik RBwAPG-5HacD2HnD AP which I need to connect to a Router which is C52iG-5HaxD2HaxD. The device says connected via WiFi2 on the C52iG and wlan1 on the RBwAPG. However ping doesn’t work and internet is not connected. I’m not sure what I’m missing.
Station Config
STNConfig.rsc (1.64 KB)
Router Config (AP)
RTRConfig.rsc (9.52 KB)
Can you make a small drawing of what you are trying to accomplish ?
Paper is good enough, doesn’t have to be high-res-publisher stuff.
Also devices behind RBwAPG.
Side note already:
AX line uses wifiwave2 package and that driver does not support 4-way address mode like legacy wifi devices could.
So if your aim is to transparantly bridge wAP and subsequent devices to same network as AX2, that can not be done anymore (for now ? Nobody knows.)
You can connect them but then you need to setup new subnet on wAP for all devices behind it.
If there are devices behind which also need to be connected to from AX2-network, you have a problem (but also that can be solved with some minor performance impact, using EOIP link over those 2 devices since they are both Mikrotik)
First your drawing please :slight_smile:
