I made a Calea Data Retention Server on MT 3.20. I have two Calea clients, 2.9.51, 3.15.
If I try to open 0000x.dmp with Tshark or Wireshark I give the following error:
tshark: “00001.dmp” appears to be damaged or corrupt.
(pcap: File has 292356096-byte packet, bigger than maximum of 65535)
I have this problem on Linux and Windows, too.
Any idea?
Im having the exact same problem.
Logging data from an AP to a Calea server, but when i pull the file from the server i get the same wireshark message.
Thank you for the report.
The report was accepted and we are working on the problem.
We are sorry for such delay, but it would be great if the next time you will report problem to support@mikrotik.com (support department), not just here in the forum.
