Wireshark with mikrotik
Hi
I would know what is the benefit “Wireshark” with mikrotik,
Wireshark that have method to drop “netcut”? , and show any one user to who using any program attack to server mikrotik or netcut and other program.
Regards
Wireshark is a packet capture tool and as such will only receive packets, not transmit them [it is passive].
You may use it to look at ARP responses and manually check if the sending MAC addresses is what it should be. There may even be an “expert info” entry that highlights where ARP entries are cycling between different MAC addresses.
Thank you for your command
