WISP OSPF MPLS VPLS Problem
We are WISP company and trying to change our structure from bridging to MPLS VPLS routing ,
Already setup that and work the OSPF and MPLS great.
We have already MPLS till the client reciever antenna client is an Sektor connected .
OSPF end on Sektor and MPLS end an client antenna , I can ping from client antenna all ip on sector and pppoe Server as long as loopback IP , but vpls is running in one way (pppoe Server) but wont run on client antenna, vpls between Sektor and pppoe Server works, but vpls client antenna and pppoe Server won’t work .
Any Idea will be so appreciated.
Best regards
Gesendet von iPhone mit Tapatalk
Why do you even want VPLS tunnels on the client radios? If you have pppoe and you set up vpls on the client radio that means you need one vpls tunnel per pppoe customer, which seems excessive.
