WISP service profiles
Hello
With ouer wimax equipment we use a sentral control software where we can see the coustomers signal up/down, error frames etc.
We also control service profiles etc “basic” 2000/500Kbps “fast” 3000/1000Kbps “super” 4000/1500Kbps etc.
Coustomers witch don`t pay, we just disable the profile.
Just starting now with the wimax equipment I see that there is a qos setting witch can be set on each CPE, but if I change profiles from lets say 2000 to 2500Kbps I would have to do this on each CPE :open_mouth: He he, so I guess that is not how you do it. How do you wisp in here manage this?
I guess for signal and monitoring I could use the dude or cacti.
would like to know which software & hardware are you using ?
if your asking if you can do these same things on mikrotik, the answer is YES.
ur question is not clear however.
