Hi
I`m setting up a RB1100 to use with usermanager.
What is the best perfoming, most stable relese yet?
Need some help choosing ![]()
Hi
Sorry for troubling you with this.
But I realy need some tips here.
Need high performance and stability.
Witch version do you reccomend.
We just upgraded to v5rc4-beta from v4.11-usermantest all went well and been working fine for a week.
Thank you.
I installed UM 4.16, and all seems fine ![]()
How many users have you got on you RB1100?
UM 4.16 and 5.0RC8 both do not work for me.
Was running 5.0RC8 for a few days, then suddenly it started not authenticating logins.
Just says “PPPoE connection from was already active - closing previous one”.
An then in PPP sessions pppoe-0 appears, in stead of customer name, and it just drops.
Sometimes it helps deleting customer form UM and adding new customer with same login/password.
I had this problem before with other releases.
Is your RC4 still running fine?
For anyone else interested, I found 4.11 to work for me.
The newer ones seems to be broken.
At least for me, I use PPPoE and Usermanager.
