with lhg 5 I can not see local cameras
I have an antenna with lhg 5 attached to a router mr3320 tp lin via the wan port
the point and that now attaching my dvr to the router I can not see my remote cameras as I did before having only the router with my
question how to configure lhg 5 mikrotik to see the cameras in local
Either bridge the network or redirect the necessary ports if you are natting inside your network. Having mikrotik on only one side of the link effectively prevents you from using the transparent bridging mode.
It can connect to the network or reduce the ports you need if you are natting inside the network.
ok with translation is not so much understood
how do I proceed then what should I configure?
What’s your native language?
italian
https://www.youtube.com/watch?v=9Tu_1qqx1LA&t=292s
I should practically do this or not
Alright, maybe we can get a native Italian speaker to help.
))) WiFi ((( – WAN – – LAN – DVR
^^ Is this how your camera’s and DVR are connected today?
If so, you cannot see the cameras because the TP-Link is likely performing network address translation (NAT) between the WAN and LAN. You either need to setup network address translation (NAT) rules on the TP-LInk to translate the IP addressing on the camera’s and LHG units to LAN IPs or more likely you need to create a layer 2 domain (bridge) that the camera’s and DVR unit share. The shared layer 2 domain is likely the solution you need. Most camera systems use discovery methods that are link-local and are unable to pass routed interfaces (also unable to pass through NAT boundaries). If my drawing is accurate, you can bridge the two LHG units and connect them to the LAN interface of your TP-Link. As long as the IP addressing is within a common network everything will work. Their are several ways you could do this in a better manner but we’d need to get past the communication barrier.
It would help to post a drawing of what you are trying to do. Even something drawn on a napkin and a picture taken of it with a cell phone will do if you don’t have Microsoft Visio.
here is the graph of how and connected
Why not plug the DVR directly into the LHG?
because i can not connect to the internet with computers
Draw how the cameras are connected please.
simply by means of the appropriate sockets
https://www.youtube.com/watch?v=lspWhGONU3U
complete situation
situation summary
if I enter my local address 192.168.x.xx from my browser, I can not connect to the dvr
Is that while you’re connected to WiFi locally or are you trying to access the DVR somewhere on the Internet?
with this situation I could see it very well before
I access the cameras locally ie where and physically located lhg5
Is the LHG connected to the Internet directly or is it be used to connect to another location?
Are you able to configure the LHG? If so, please run the command:
/export hide-sensitive
Just to be certain. You are trying to access the DVR system locally and remotely?
Like Jarda said the LHG and the TP-Link are both likely doing NAT, network address translation. That’s most likely your problem but I need to know what the LHG connects to and if it is public or private IPv4 addressed to be certain.
I connect locally to the dvr by accessing the default ip address 192.168.xx.x
lhg 5 and connected directly to the internet
if I access the lhg 5 setting by win box me from this error
tell me how I can proceed
lhg5 as the activation of the subscription I did by a technician, so I do not know in combination
if I have to reset everything tell me how I should proceed
