With Mikrotik 7 with two gateway I get slower speed
Dear Community,
I used multiple gateways in the past with Mikrotik 6, I tried to do the same with mikrotik 7.
The gateways works but the speed that I get is much slower.
It looks like the router is trying to balance as much as possible the speed but in doing so it is making the cumulative speed slower.
I remeber that with mikrotik 6 it worked much better I got more speed.
Is there some new configuration that need to me make in the newest version of routerOS?
Thank you.
Best Regards.
