i bought a RB951G last week, with RouterOS ~5.26, i update it to lastest 6.10… plus probably also FW update, im not sure by this, i update all what i found…
i did some Logging rules, then i turned RB off, and it doesn´t start anymore…
I have tryed:
NetInstall RouterOS: 5.26, 6.0rc11 ,6.10.
installation is always done, router restarts, i heard some beep sounds, mostly defected, that’s it. NO wifi, no connection with winbox…
Question is how can i downgrade FW file or do you have any another idea?
All my Mikrotik routers boot with a single beep, followed a few seconds later with a double beep. Is that what you get?
Do you have the latest version of Winbox? ROS v6.X is particular about that. Go to the download section to get it. Start Winbox and click on the “…” button. It should list the Mikrotik devices by mac address. See if you can connect that way.
details:
since i get successful update, it has mostly only one defected beep.
now after start i heard a little bit defected beeeeep long cca 2 sec, but then i get two next normal beeps …
Then i tried, as you said, connect through MAC address in Winbox, and its working, it connected, i can turn on wifi, it seems working again!
