Without DHCp server
My network is already running with the static Ip for all pc,s now i want to install the Mikro TIk for Internet & I don’t want to disturb the previous static setup in my network.
will the mikro tik supports?
Hi Nirmal
Yes, you can install the Mikrotik without using DHCP
Obviously, you’ll need to set the static address of the Router to the same gateway as statically configured on your Network Clients.
That’s the best answer I can give without some more detailed information.
