WLAN-Bridge Connection unstable und slow
Hello.
I have realized in our company a WLAN bridge to connect two locations. The sketch shows the structure of the connection. I have made screenshots of individual systems and their configuration.
I am referring 4 MECONET MOR-19-16DP-911-5G, 1GIGE, 1802.11A/N WITH 2*2 MIMO, 300MBIT/SEK - This type. Firmware is on all routers the 3.33 and the ROS in the version 6.38.1.
The connections are not performant (~ 1MB / sec) and there are crashes and very long loading times.
The configuration I have tried after various instructions and am not sure if everything is correct. Can the experts look where I can still make changes to get a stable and fast connection?
If you need more information or logs, please tell me.
I thank all for your help.
Greetings from Germany.
With These Bad Signal Levels, around -80, you wont get more Speed…
Grüsss aus RHLP
Mistry7
After some hints I have now selected as wireless protocol 802.11. Now the connection is faster and also 2 streams are used. The connection fluctuates very much, changing the speeds at all times.
Which setting do I have to make, so that the fastest and most stable connection permanent remains? Can I optimize the transmission power of the antenna still something?
I have again the current settings as screenshot appended and the configs of the individual rout are synonymous with it.
I would appreciate an answer.
and here are the configs
System-A1
[meconet@System-A1] > export
# feb/27/2017 07:46:39 by RouterOS 6.38.1
# software id = D0VD-3T2Y
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=16 band=5ghz-onlyn channel-width=20/40mhz-Ce comment="remote LAN behind System-B -> Interface in bridge1" country=germany disabled=no frequency=5560 \
    frequency-mode=regulatory-domain hide-ssid=yes ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 hw-protection-mode=rts-cts mode=bridge multicast-buffering=disabled nv2-cell-radius=10 nv2-preshared-key=\
    "XXX" nv2-security=enabled radio-name=sys-a_w1 rate-set=configured rx-chains=0,1 ssid=5GHz-PtP-1 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps tx-chains=0,1 wireless-protocol=802.11 wps-mode=\
    disabled
add admin-mac=00:0C:42:C5:F9:96 auto-mac=no comment="bridge ether1 & wlan1 transparently" mtu=1500 name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] comment="local LAN -> Interface in bridge1"
/interface wireless nstreme
set wlan1 comment="remote LAN behind System-B -> Interface in bridge1" disable-csma=yes enable-nstreme=yes enable-polling=no
/interface wireless manual-tx-power-table
set [ find default=yes ] supplicant-identity=""
add authentication-types=wpa2-psk management-protection=required management-protection-key="XXXX" mode=dynamic-keys name=wpa2-not_used_for_NV2 supplicant-identity="" wpa2-pre-shared-key=\
    "XXX"
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
/system logging action
set 0 memory-lines=500
/tool user-manager customer
set admin access=own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge1 interface=wlan1
/ipv6 settings
set accept-redirects=no forward=no
/interface wireless access-list
add comment="ALLOW System-B to connect" interface=wlan1 mac-address=D4:CA:6D:AF:43:61 signal-range=-90..120
add address=192.168.10.60/24 interface=ether1 network=192.168.10.0
/ip dhcp-client
add comment="management IP" default-route-distance=0 dhcp-options=hostname,clientid interface=bridge1
set servers=192.168.10.4,192.168.10.2
add distance=1 gateway=192.168.10.254
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Berlin
/system identity
set name=System-A1
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
/system leds
set 0 interface=wlan1
/system logging
add topics=wireless
add topics=interface
add topics=account
add topics=event
add topics=system
add topics=state
/system note
set note="System information: RouterBOARD 911G-5HPnD, S/N 4A440118A121, SW-ID D0VD-3T2Y"
/system routerboard settings
set init-delay=0s
/tool bandwidth-server
set enabled=no
/tool graphing interface
add interface=bridge1
add interface=wlan1
add interface=ether1
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool user-manager database
set db-path=user-manager
System-B1
[meconet@System-B1] > export
# feb/27/2017 07:00:37 by RouterOS 6.38.1
# software id = 91GZ-ITF1
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=16 band=5ghz-a/n channel-width=20/40mhz-Ce comment="remote LAN behind System-A -> Interface in bridge1" country=germany default-forwarding=no disabled=no \
    frequency=auto frequency-mode=regulatory-domain ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 hw-protection-mode=rts-cts mode=station-bridge multicast-buffering=disabled nv2-preshared-key=\
    "XXX" nv2-security=enabled radio-name=sys-b_w1 rate-set=configured rx-chains=0,1 ssid=5GHz-PtP-1 tx-chains=0,1 wireless-protocol=802.11
add admin-mac=D4:CA:6D:AF:43:60 auto-mac=no comment="bridge ether1 & wlan1 transparently" mtu=1500 name=bridge1 protocol-mode=none
set wlan1 comment="remote LAN behind System-A -> Interface in bridge1" enable-nstreme=yes
/ip neighbor discovery
set ether1 discover=no
set wlan1 discover=no
    "XXX"
add interface=bridge1 lease-time=3d name=dhcp1
/ip ipsec proposal
/interface wireless connect-list
add comment="ALLOW connect to System-A" interface=wlan1 mac-address=00:0C:42:C5:F9:97 security-profile=default signal-range=-90..120 ssid=5GHz-PtP-1 wireless-protocol=tdma
add address=192.168.10.61/24 interface=ether1 network=192.168.10.0
/ip dhcp-client
add comment="management IP" dhcp-options=hostname,clientid interface=bridge1
/system clock
/system identity
set name=System-B1
/system lcd
/system lcd page
/system leds
/system logging
add topics=wireless
add topics=account
add topics=event
add topics=system
add topics=state
/system note
set note="System information: RouterBOARD 911G-5HPnD, S/N 4A4402789274, SW-ID 91GZ-ITF1"
set init-delay=0s
set authenticate=no
add interface=wlan1
add
/tool mac-server
set enabled=no
System-A2
[meconet@System-A2] > export
# jan/05/2002 23:38:20 by RouterOS 6.38.1
# software id = 8PIF-A7XZ
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=16 band=5ghz-onlyn channel-width=20/40mhz-Ce comment="remote LAN behind System-B -> Interface in bridge1" country=germany disabled=no frequency=5660 \
    "XXX" nv2-security=enabled radio-name=sys-a_w1 rate-set=configured rx-chains=0,1 ssid=5GHz-PtP-2 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps tx-chains=0,1 wireless-protocol=802.11 wps-mode=\
    disabled
add admin-mac=D4:CA:6D:AF:43:14 auto-mac=no comment="bridge ether1 & wlan1 transparently" mtu=1500 name=bridge1 protocol-mode=none
    "XXX"
/ip ipsec proposal
add comment="ALLOW System-B to connect" interface=wlan1 mac-address=00:0C:42:C5:F9:9B vlan-mode=no-tag
add address=192.168.10.62/24 interface=ether1 network=192.168.10.0
/ip dhcp-client
/system clock
/system identity
set name=System-A2
/system lcd
/system lcd page
/system leds
/system logging
add topics=wireless
add topics=account
add topics=event
add topics=system
add topics=state
/system note
set note="System information: RouterBOARD 911G-5HPnD, S/N 4A4402DC66B6, SW-ID 8PIF-A7XZ"
set init-delay=0s
set enabled=no
add interface=wlan1
add
/tool mac-server
set enabled=no
System-B2
[meconet@System-B2] > export
# jan/07/2002 20:00:25 by RouterOS 6.38.1
# software id = F2HH-TJ8P
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode antenna-gain=16 band=5ghz-a/n channel-width=20/40mhz-Ce country=germany disabled=no frequency=5660 frequency-mode=regulatory-domain ht-supported-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 mode=station-bridge multicast-buffering=disabled nv2-preshared-key="XXX" nv2-security=enabled radio-name=sys-b_w1 rate-set=configured rx-chains=0,1 ssid=\
add name=bridge1 protocol-mode=none
set wlan1 enable-nstreme=yes
set [ find default=yes ] supplicant-identity=meconet
add comment="Allow Connect System A" interface=wlan1 mac-address=D4:CA:6D:AF:43:15 security-profile=default ssid=5GHz-PtP-2 wireless-protocol=tdma
add address=192.168.10.63/24 interface=ether1 network=192.168.10.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge1
/system identity
set name=System-B2
/system lcd
/system lcd page
/system note
set note="System information: RouterBOARD 911G-5HPnD, S/N 4A440118A12D, SW-ID F2HH-TJ8P"
set init-delay=0s
This is normal, the displayed rate in wireless/registration depends on the demand.
Initiate a big file transfer between the two sides and monitor your WLAN interfaces. Rate should increase to its maximum. Is the throughput stable ?
Have you done a wireless/spectral-scan/spectral history to ckeck if the channel(s) you use are not busy?
You can also use the bandwidth test tool between each wireless link (60<->61 and 62<->63) to see if there is a weak(er) link that could mess the whole connection.
