Introductions
I have been using Mikrotik for years and slowly migrated most of my family to use it, but I am not a network person. I am very comfortable on a Linux CLI but generally prefer the web GUI on Mikrotik.
Hardware Setup
- hAP ax3 (Primary)
- hAP ax2 (Extender)
Wireless Network Setup
- Primary 2G networked
- Primary 5G networked
- Secondary 2G client isolated (aka common)
- Secondary 5G client isolated (aka common)
Problem
After an upgrade from 7.12 (I think) to 7.18.2 packages and firmware, some things broken/stopped working.
Best i can tell, it looks like DHCP is no-longer working on the secondary 2G wlan and the Primary 5G wlan, but if I set a fixed IP clients can connect.
DHCP seems to work on Ethernet and Primary 2G and Secondary 5G wlan.
Question
I have been clicking through settings for a few hours now and cant figure out what is the problem. Any guidance or help would be greatly appreciated.
Settings Export
# 2025-04-27 16:17:09 by RouterOS 7.18.2
add name=bridge-common port-cost-mode=short
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=\
bridge-network port-cost-mode=short
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=wlan-common-list
add name=wlan-network-list
/interface wifi channel
add band=2ghz-ax comment=2G-WIFI6 disabled=no frequency=2442-2462 name=\
channel1-2G-W6 skip-dfs-channels=10min-cac width=20/40mhz
add band=2ghz-n comment=2G-WIFI4 disabled=yes frequency=2412-2422 name=\
channel5-2G-W4 skip-dfs-channels=all width=20mhz
add band=5ghz-ax comment=5G-WIFI6 disabled=no frequency=5180-5320 name=\
channel2-5G-W6 skip-dfs-channels=10min-cac width=20/40/80mhz
add band=5ghz-ac comment=5G-WIFI5 disabled=yes frequency=5180-5320 name=\
channel3-5G-W5 skip-dfs-channels=all width=20/40/80mhz
add band=2ghz-g comment=G2-WIFI3 disabled=yes frequency=2412-2422 name=\
channel5-2G-W3 skip-dfs-channels=all width=20mhz
/interface wifi datapath
add client-isolation=yes comment=common-isolation disabled=no interface-list=\
wlan-common-list name=datapath-isolation
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk comment="Common security profile" \
disable-pmkid=yes disabled=no eap-certificate-mode=\
dont-verify-certificate ft=yes name=sec-sid-common wps=disable
add authentication-types=wpa2-psk,wpa3-psk comment=\
"Networked security profile" disable-pmkid=yes disabled=no name=\
sec-sid-network wps=disable
/interface wifi configuration
add channel=channel1-2G-W6 disabled=no mode=ap name=cfg-sid-common-2G \
security=sec-sid-common security.ft=yes ssid=sid
add channel=channel1-2G-W6 country="South Africa" disabled=no mode=ap name=\
cfg-sid-network-2G security=sec-sid-network security.ft=yes ssid=\
sid-N
add channel=channel2-5G-W6 country="South Africa" datapath=datapath-isolation \
disabled=no mode=ap name=cfg-sid-common-5G security=sec-sid-common \
security.eap-certificate-mode=dont-verify-certificate .ft=yes ssid=\
sid-5
add channel=channel2-5G-W6 country="South Africa" disabled=no mode=ap name=\
cfg-sid-network-5G security=sec-sid-network security.ft=yes ssid=\
sid-N5
/interface wifi
set [ find default-name=wifi1 ] channel=channel2-5G-W6 comment=\
"Primary 5G Wifi 6 (ax)" configuration=cfg-sid-network-5G \
configuration.mode=ap disabled=no name=wlan1-5G-W6
set [ find default-name=wifi2 ] channel=channel1-2G-W6 \
channel.skip-dfs-channels=all comment="Primary 2G Wifi 6 (ax)" \
configuration=cfg-sid-network-2G configuration.mode=ap disabled=no \
name=wlan2-2G-W6 security.ft=yes
add comment="Common 2G Wifi 6 (ax)" configuration=cfg-sid-common-2G \
configuration.mode=ap disabled=no mac-address=4A:A9:8A:0A:27:88 \
master-interface=wlan2-2G-W6 name=wlan3-common-2G-W6
add comment="Common 5G Wifi 6 (ax)" configuration=cfg-sid-common-5G \
configuration.mode=ap disabled=no mac-address=4A:A9:8A:0A:27:87 \
master-interface=wlan1-5G-W6 name=wlan4-common-5G-W6
add name=dhcp-pool-network ranges=192.168.0.100-192.168.0.200
add name=dhcp-pool-common ranges=192.168.1.100-192.168.1.200
add address-pool=dhcp-pool-network interface=bridge-network lease-time=2h \
name=dhcp-network
add address-pool=dhcp-pool-common interface=bridge-common lease-time=8h name=\
dhcp-common
/port
set 0 name=serial0
/user group
add comment="Home assistant Integration Group" name=home policy="read,write,po\
licy,test,api,!local,!telnet,!ssh,!ftp,!reboot,!winbox,!password,!web,!sni\
ff,!sensitive,!romon,!rest-api"
add bridge=bridge-network comment=defconf interface=ether2 \
internal-path-cost=10 path-cost=10
add bridge=bridge-network comment=defconf interface=ether3 \
add bridge=bridge-network comment=defconf interface=ether4 \
add bridge=bridge-network comment=defconf interface=ether5 \
add bridge=bridge-network comment=defconf interface=wlan1-5G-W6 \
add bridge=bridge-network comment=defconf interface=wlan2-2G-W6 \
add bridge=bridge-common interface=wlan3-common-2G-W6
add bridge=bridge-common interface=wlan4-common-5G-W6
add bridge=bridge-common interface=wlan-common-list internal-path-cost=10 \
path-cost=10
add bridge=bridge-network interface=wlan-network-list internal-path-cost=10 \
path-cost=10
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=yes \
use-ip-firewall-for-vlan=yes
set udp-timeout=10s
/ip settings
set rp-filter=strict
/ipv6 settings
set max-neighbor-entries=15360
add comment=defconf interface=bridge-network list=LAN
add interface=wlan3-common-2G-W6 list=wlan-common-list
add interface=wlan4-common-5G-W6 list=wlan-common-list
add interface=wlan1-5G-W6 list=wlan-network-list
add interface=wlan2-2G-W6 list=wlan-network-list
/interface ovpn-server server
add mac-address=FE:8A:43:5A:E0:D2 name=ovpn-server1
/interface wifi access-list
add action=accept comment=M1 disabled=yes interface=any mac-address=\
XX:XX:XX:XX:XX:XX signal-range=0 time=0s-0s
add action=accept comment=M2 disabled=yes interface=any mac-address=\
add action=accept comment=M3 disabled=yes interface=any \
mac-address=XX:XX:XX:XX:XX:XX signal-range=0 time=0s-0s
add action=accept comment=M4 disabled=yes interface=wlan-common-list \
add address=192.168.0.1/24 comment=defconf interface=bridge-network network=\
192.168.0.0
add address=192.168.1.1/24 interface=bridge-common network=192.168.1.0
/ip dhcp-client
add address=192.168.0.0/24 comment=defconf dns-server=10.0.0.1 gateway=\
192.168.0.1
add address=192.168.1.0/24 dns-server=10.0.0.1 gateway=192.168.1.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=drop chain=forward comment="Block common form network" \
dst-address=192.168.0.0/24 src-address=192.168.1.0/24
add action=drop chain=forward comment="Drop common to common" in-interface=\
bridge-common out-interface=bridge-common
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
ipsec-policy=out,none out-interface-list=WAN src-address=192.168.0.0/24
add action=masquerade chain=srcnat comment=nat-common out-interface-list=WAN \
/ip ipsec profile
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set www-ssl certificate=WebFigCrt disabled=no
set api disabled=yes
set api-ssl certificate=WebFigCrt
/ip ssh
set host-key-size=4096 strong-crypto=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Place/City
/system identity
set name=sid-HA
/system logging
add topics=wireless,debug
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
