helo everybody.
i have a hex poe lite and 2 pieces map lite. I have configured a CAPsMan wifi network.
Please.
Can you tell me where I can set the Mbit / s speed limit for one network?
I want different speeds for GUEST and the main network.
Can I set a maximum of 10 Mbit / s for one random client?
Thankgs
best regards
I think the easiest way to set this up is with simple queues, I guess you could either use a simple queue to target the IP/subnet of the guest, main network and specific user or you could possibly have an interface queue for the 2 different wlan interfaces and then have a simple queue for the specific user? either way I would recommend you having a look at the wiki page to get an idea of how this works then go from there
https://wiki.mikrotik.com/wiki/Manual:Queue
