Hi
I was connected to a wireless user group and took down my router. when i reconfigured my router to rejoin it works 100%
accept may gateway stays unreachable and in my log it shows at times.
“Wlan, lost connection not polled for to long” Can anyone tell me what this is please.
Is this why my gateway stays unreachable???
Thanks in advance
Hi, Did you check your signal strength?
My signal on my wlan is at a constant -71/-72 CCQ of about 60%
So tell me about your Router model? Do you use it for Indoor or Outdoor? How much is the distance? Antenna Gain? dBi? How many clients connect to the Access Point Which you connected? when you are connected, what is you ping time to AP?
