WLan Disconnects frequently
HI,
Can someone please assist…
we experience an issue on a mikrotik 951 routerboard where the Wlan disconnects and drops all connections frequently and then reconnect all devices.
I have changed the lease time but it still happens often.
Attached is the error.
Routeroard has been replaced, sofware is on 6.42.2…the issue is that the eth doesnt disconnects only the Wlan that drops all connections and reconnects every minute or so and then reassociate.
Ssid has been changed to test , security key psk and psk2 has been altered on and off but nothing seems to resolve the problem.
Any assistance would be highly appreciated.
Regards
Izak Bezuidenhout
This log only shows one single minute.
Do you also face “disconnected, group key exchange timeout” or “disconnected, unicast key exchange timeout” issues?
If yes, you are not alone and should use the two existing threads for it.
