HI, i have problems with wireless interface on 2,4 ghz. When router restart after booting wlan interface don’t work. I have rx packet on wlan but i don’t have tx packet. dhcp give network address to clients. When i disable and enable wlan interface then wlan interface start working. I use radius to control mac based authentication.
[admin@UDRIGOVO AP1] > /interface wireless print
0 R name=“wlan2” mtu=1500 mac-address=00:FF:76:21:17:CB arp=reply-only interface-type=Atheros AR5212 mode=ap-bridge
ssid=“Wireless 5” frequency=2417 band=2.4ghz-b scan-list=default antenna-mode=ant-b wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no default-authentication=no default-forwarding=no default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=profile1 compression=no1 R name=“wlan1” mtu=1500 mac-address=00:0C:42:1B:25:6D arp=reply-only interface-type=Atheros AR5413 mode=ap-bridge
ssid=“Wireless” frequency=2447 band=2.4ghz-b scan-list=default antenna-mode=ant-a wds-mode=disabled
default-client-tx-limit=0 hide-ssid=no security-profile=profile1 compression=no2 R name=“wlan3” mtu=1500 mac-address=00:0B:6B:09:C4:53 arp=enabled interface-type=Atheros AR5213 mode=ap-bridge
ssid=“UDRIGOVO-PRIBOJ” frequency=5280 band=5ghz scan-list=default antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
[admin@UDRIGOVO AP1] > /interface wireless security-profiles print
0 name=“default” mode=none authentication-types=“” unicast-ciphers=“” group-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“” supplicant-identity=“UDRIGOVO AP1” tls-mode=no-certificates tls-certificate=none
static-algo-0=none static-key-0=“” static-algo-1=none static-key-1=“” static-algo-2=none static-key-2=“”
static-algo-3=none static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none static-sta-private-key=“”
radius-mac-authentication=no radius-mac-accounting=no radius-eap-accounting=no interim-update=10s
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username radius-mac-caching=disabled group-key-update=5m1 name=“profile1” mode=none authentication-types=“” unicast-ciphers=“” group-ciphers=“” wpa-pre-shared-key=“”
radius-mac-authentication=yes radius-mac-accounting=no radius-eap-accounting=no interim-update=15s
Thanks for help.
