WLAN problem on RB751U-2HnD
I have a WLAN problem on RB751U-2HnD.
Everything works fine, but one device in WLAN segment cannot ping another one in a same WLAN segment.
Both have IP addresses from same subnet, and both devices have internet, as well.
It might be a firewall issue, but I am not familiar with rules, needed to be applied.
May someone advice me?
check your wireless configuration for
if default forwarding is enabled .
default-forwarding (yes | no; default: yes) - to use data forwarding by default or not.
If set to ‘no’, the registered clients will not be able to communicate with each other
IF that is not the issue. check the ip firewall … and post the rules here.
you can post firewall settings from mikrotik here… but did you try turning off thr firewall on that devices (windows OS ?)
It was “Default Forward” option on Wireless Tab.
I just checked the box and now everything works fine.
Thanks for quick answer and help.
