WLAN to LAN connection in VLAN not possible
Hello all,
I face a problem regarding the connection from one client on WLAN to another client in LAN. It is not possible to establish a connection inbetween them. Both are in the same VLAN.
Please find attached my config file.
Any hints for me to get this problem solved? Your help is really appreciated.
I am not an expert → please (if possible) send me a step by step instruction where to change or adapt.
Regards
Thorsten
config.txt (76.8 KB)
No one an Idea?
Thank you very much in advance.
Regards
Thorsten
If they are in the same vlan then they are connected on layer2. Makes no sense.
Unless you reinvent rules, I see you have two bridges, first mistake and then attempt to assign the same vlan IDs to different vlans on the different bridges
Good luck with that.
