hello all,
i have a ptp link between two RB912UAG-5HPnD
from time to time the one used as bridge, stops working with these messages in log file
wlan1: must select channel
wlan1: failed to select channel
this is the configuration:
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap eap-methods="" \
group-ciphers=tkip,aes-ccm management-protection=allowed mode=dynamic-keys \
name=kokoriko supplicant-identity="" unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2,3,4,5,6,7 band=5ghz-a/n \
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
channel-width=20/40mhz-Ce country=no_country_set disabled=no frequency=5500 \
frequency-mode=manual-txpower ht-basic-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mc\
s-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16\
,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" mode=bridge \
multicast-helper=full noise-floor-threshold=-110 nv2-cell-radius=10 \
nv2-security=enabled rate-set=configured rx-chains=0,1 security-profile=\
kokoriko skip-dfs-channels=all ssid=twmn::phil2lewis station-roaming=\
enabled tdma-period-size=auto tx-chains=0,1 wireless-protocol=nv2-nstreme \
wmm-support=enabled
/interface wireless nstreme
set wlan1 enable-polling=no framer-policy=best-fit
what am i doing wrong ?
