wlan1 setup
Hello, I would like to setup my RouterBoard 133c wlan1 to connect to my other wireless router (just a normal router purchased at retail store) connected to the DSL modem. The reason to do this is to make my PC connect to the internet through RouterBoard wirelessly. However, I cannot setup the wlan1 interface to connect to the wireless router. Please advice what to do. Below is the setup for the wlan1 interface:
[admin@MikroTik] > /interface wireless print
0 name=“wlan1” mtu=1500 mac-address=00:0B:6B:85:62:F7 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name=“000B6B8562F7” mode=station ssid=“VW_SMC” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2462 band=2.4ghz-b/g scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms hw-retries=15 preamble-mode=both
compression=no allow-sharedkey=no
Thank you very much.
Just want to point out that I’ve ping from my PC to ethan1 to wlan1 and it can get through. So the problem should be the wireless connection.
