wlan2: disconnected, decided to deauth
hi there!
i have following problem:
rb532a as AP and an OSBRIDGE for 2.4 ghz as an client.
the important thing is, that the signal is at about -42 dBm - i have tried to make the signal weaker, now i have around
-65 dBm .. but the strange thing is, that actually the performance is pretty nice, after a few days the client disconnects.
(independend on my tests.. - its already an older hardware revision (rev 1) of the osbridge)
the MT-AP gets following errormessage:
wlan2: disconnected, decided to deauth: group key handshake timeout (16)
what could be the reason for it??
any suggestions/help would be really appreciated!
thanks!
chris
try to xhange the frequency.. or try to to configure not same with other interfaces…
if again it disconnected, and decided to deauth try to disable all client , and then enable one by one , and look cause maby any client may be infected ..or you dont have another choise just to change the hardware i mean cable, prism, or antena…
reguards…
