I have a rather strange setup and suspect that it may contribute to the fact that I can’t get WOL to turn on a computer. (I have confirmed its turned on in the computers bios)
On a Hex S I have ether1 connected to Wan, ether2-ether4 connected to the standard bridge on the 192.168.50.0/24 subnet (with none actually being used), and ether 5 connected to the computer on a special VPN-bridge on the 10.39.26.4/30 subnet. The router has an address of 192.168.50.1 and 10.39.26.5 on the respective subnets, and the computer has an address of 10.39.26.6. Try as I may I can’t get the computer to turn on using the WOL tool on the MikroTik.
router export:
add name=VPN-bridge
add admin-mac=hidden auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=aes-256 name=VPN-profile
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 name=MGMT-profile
/ip ipsec peer
add address=hidden exchange-mode=ike2 local-address=hidden name=MGMT-peer port=4501 profile=MGMT-profile
add address=hidden exchange-mode=aggressive local-address=hidden name=VPN-peer profile=VPN-profile
/ip ipsec proposal
add enc-algorithms=aes-256-cbc lifetime=1d name=VPN-proposal
add enc-algorithms=aes-256-cbc lifetime=1d name=MGMT-proposal pfs-group=modp2048
add name=default-dhcp ranges=192.168.50.10-192.168.50.254
add name=VPN-pool ranges=10.39.26.6
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=VPN-pool disabled=no interface=VPN-bridge name=VPN-dhcp
add bridge=VPN-bridge comment=defconf interface=ether5
add bridge=bridge comment=defconf interface=sfp1
add interface=VPN-bridge list=LAN
add address=192.168.50.1/24 comment=defconf interface=bridge network=192.168.50.0
add address=hidden comment=VPN-autogen-public interface=ether1 network=hidden
add address=10.39.26.5/30 comment=VPN-autogen-private interface=VPN-bridge network=10.39.26.4
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.39.26.4/30 comment=VPN-autogen-dhcp-network dns-server=10.39.26.5 gateway=10.39.26.5
add address=192.168.50.0/24 comment=defconf gateway=192.168.50.1 netmask=24
set allow-remote-requests=yes servers=10.39.80.1
add action=accept chain=input src-address=10.39.26.0/24
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add chain=srcnat comment=VPN-autogen-srcnat dst-address=10.0.0.0/8 src-address=10.39.26.4/30
add chain=dstnat comment=VPN-autogen-dstnat dst-address=10.39.26.4/30 src-address=10.0.0.0/8
/ip ipsec policy
add action=none dst-address=10.39.26.4/30 src-address=0.0.0.0/0
add dst-address=10.39.26.248/30 peer=MGMT-peer proposal=MGMT-proposal sa-dst-address=hidden sa-src-address=hidden src-address=10.39.26.4/30 tunnel=yes
add dst-address=10.0.0.0/8 peer=VPN-peer proposal=VPN-proposal sa-dst-address=hidden sa-src-address=hidden src-address=10.39.26.4/30 tunnel=yes
add distance=1 dst-address=10.0.0.0/8 gateway=VPN-bridge pref-src=10.39.26.5
