WOL
Hello
i want to use wake on lan facnction but when i click on one routerboard shutdow and want to wake up it from another mikrotik in same subnet nothing is heppening,
do i need to configure anything else on routerboard?
Routerboards do not have support to be WOL destination devices.
Sorry to use your topic but the title suits…
Got ROS 3.30.
I’m trying to use WOL but have been unable to make it work.
i’m using the syntax /tool wol interface=
Nothing happens… anyone been successful on using WOL on this version?
Does the target device support this feature? Is target device on same the LAN segment?
yes and yes.
wake on lan gui from depicus’ site works without problems.
Tried to use packet sniffer to check if the packet gets sent but no luck :confused:
it is simple ethernet interface or some bridge or even something else.
simple ethernet if (local side of a adsl connection)
It seems problem is in v3.30. WOL in v4.x, v5.x works fine.
