Just received my brand news woobm.
In the console i’m unable to do copy and paste.
do you know how it is doable or if it’s going to be a future feature ?
thanks
thanks
From the web interface if you click on home, then you’ll be able to telnet to the woobm via the same IP you use for the web interface to get console access to whatever you have it plugged into. From your telnet client you should have no prob with copy/paste. This is what I do.
